Author Topic: Running at 70°C heat temp, average 25mpg on the motorway!  (Read 2713 times)
Offline Shady Pioneer
  • graphic designer.
On the way back from Volksfest I noticed my temp gauge was down sitting at 70, it had reach 90 previously in the day when I left the engine running during pack up down in the pissing rain at Volksfest.  :rolleyes:
Flicked through to my MPG and saw after 45 minutes of driving on the motorway doing 65mph that I'd only averaged 25mpg! This is most definitely not right as I've done better driving through town. Usually on long journeys it's around 35+ depending on how fast I'm going.
What could the cause be?
Offline Screech16v
  • MK3 20vt AGU
Your stat may be stuck open :smiley:
  • graphic designer.
How would one check this?  :smiley:
Offline Screech16v
  • MK3 20vt AGU
Tell tale signs are taking alot longer than normal to warm up , never reaching normal operating temp whilst being driven,will use more fuel,they cost about £6 so very cheap to replace
Offline dom
  • Back in a Mk4
My guess would also be the thermostat. I'd change it as a first step, it's cheap & easy enough to do :wink:
Offline dragongreengolfgti
  • my golf gti mk3
after this temp sender maybe the 4 wire plug thing ?
Thermostat sticking open.
  • graphic designer.
I'll go get myself a new thermostat tomorrow then. Cheers fellas. :afro:
  • graphic designer.
Do I have to drain the coolant system? I did it last weekend.  :angry:
  • my golf gti mk3
most if not all will come out once you take the thermostat housing apart might be worth getting a new housing aswell as they like to break sometimes expect a little leak once fitted again fidly little job just make sure you get the o ring sealed properly once you re assemble  :smiley:
