Author Topic: Got my new coilpacks for free today :)  (Read 5111 times)
Offline lukeyyyyyyy21
Re: Got my new coilpacks for free today :)
« Reply #40 on: 05 July 2012, 21:37 »
Got my car in today, only replaced 2 as they said the other 2 were the right part number
still got the frickin problem though, but no error codes coming up though
Guessing its the MAF for sure now though
have you tried the ignition amp coil mounted and bolted on to the back of the air box. a possible...
spark plugs last done..
best thing you can do regarding a maf, if you have any mate with a 1.8t swop it over. from my experiernce with a quick swop over it never turned out to ever be the mas. silly things like spark plugs..
I'm guessing it can't be the ignition amp coil as its running an induction kit with the cone down near the front vents(is too much air being pushed in a possibility ???)
And it's just had a service so can't see it being the spark plugs  :undecided:
too much air being pushed in would not make your car miss fire.
if you fitted your induction kit you would have needed to relocate the ignition amp which bolts onto the air box. it is possible if it has been hanging and subject to heat that you may have a problem as it's designed to be in a colder location of the engine bay. It could be the instrument itself.
Offline gjroe78
« Reply #41 on: 05 July 2012, 21:48 »
I didn't fit it, the induction kit was fitted by the previous owner(billyvw) not sure where it is, gonna have to have a look when it stops pissin down
