Author Topic: MK3 Topping out @ 105MPH :(  (Read 3841 times)
Offline Len
Re: MK3 Topping out @ 105MPH :(
« Reply #20 on: 08 June 2011, 14:19 »
A real Gti does 135mph! :wink:
www.sas.org.uk
www.the-ace.org.uk
Offline sharki786
  • GOT BOOST??
« Reply #21 on: 08 June 2011, 15:00 »
why 135mph? it says 160mph on the clock,  :lipsrsealed:
not a real GTI then?  :grin:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline tweed
« Reply #22 on: 08 June 2011, 16:36 »
Add some power and get rid of the rev limiter and it will do 160mph alright
Offline Gash
« Reply #23 on: 09 June 2011, 12:33 »
i managed 130 and let off as got scared hah still had about 1500 rpm to go too :D
Offline Len
« Reply #24 on: 09 June 2011, 12:57 »
Man up Gash! :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline mid life crisis
« Reply #25 on: 11 June 2011, 16:27 »
Right then People just a small update:
My mate is back and he had a look and checked the timming and everything is timmed up right he said to take it to the VW boys round the corner and see what they said. They checked that again the timming come back fine but found out that the replacment coil pack I fitted last week looks wrong and they think it has a limiter in it, they also stuck it on vagcom and that come back with nothing apart from the knock sensor that they checked and gave it a clean and that was fine. So Ill have to wait till I can pick up a new coil pack from GSF next week and see what happens.
Offline Bellend
« Reply #26 on: 11 June 2011, 16:43 »
Bet the dizzy timing is out or the hall sensor at fault.
Where all my moneys went.
« Reply #27 on: 11 June 2011, 19:18 »
Dizzy is fine been checked twice,
VW BUSH
« Reply #28 on: 11 June 2011, 19:45 »
I would say the timing is out :huh:
+1 sounds like its a tooth or two out, does it hit the limiter at 5k when you clog it in 1st/2nd?
If timing is out it will register as hall effect sensor on diagnostic tool
Offline Adezmk3
« Reply #29 on: 11 June 2011, 23:33 »
My car does the same thing at 5000rpm, the car freaks out if I hit 5000, it is new to me so I thought it was just supposed to do that. I'd like to know how you get on with this as its something I think is important for me to sort out on mine.
Thanks
Adrian
