Author Topic: fitting saab injectors to mk4  (Read 22601 times)
Offline dazzifumi
« on: 04 June 2011, 08:14 »
is this a straight forward swap or does any thing need to be modified to make them fit thanks
Offline Dave_IOW
Re: fitting saab injectors to mk4
« Reply #1 on: 04 June 2011, 09:06 »
saab reds into AGU is straight swap.
AUM/AUQ different.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline dazzifumi
« Reply #2 on: 04 June 2011, 10:48 »
i have a aum i'm currently gettin the stuff together for a k04 conversion and was wanting to know what injectors to buy
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #3 on: 04 June 2011, 13:45 »
You will also need to inrease the maf area by the same % of what the saab red have increased % over the stock injectors.  This will keep the fuel trims with in reason.
Nick
 01455 617233
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 04 June 2011, 14:01 »
so bigger injectors always means bigger MAF?
Offline Grand Master Patch
« Reply #5 on: 04 June 2011, 19:57 »
Yes
Offline lukeyyyyyyy21
« Reply #6 on: 04 June 2011, 20:19 »
could you just get a maf off a bam engine vag? would that be a good match?
Offline RTechUK
« Reply #7 on: 04 June 2011, 20:31 »
No not for AGU.
 01455 617233
Offline RTechUK
« Reply #8 on: 04 June 2011, 21:07 »
AGU / cable 1.8T / motronic 5 ecu / m3.8.* ecu
The AGU uses a narrow band ecu which every thing in the mapping ie primary fuel, timing and load is ALL based around the reading from the maf.  The injection on-time is made up from maf reading, rpm and engine load.  If you fit bigger injectors then the engine will run too rich and the ecu can only trim a small amount of the extra fuel by using the narrow band 02 readings.
 If you change the MAF housing % size to the same % increase as the injectors then the ratio for injection ms and air drawn will be about spot on or within an ideal range for the ecu to trim by around 5-10%, then when is comes to mapping all we have to do is rescale the load axis on the ignition maps and fine tune the injection ms map, which can take a round a whole day to dial in from scratch. There is a way of just adding bigger injectors to the ecu but this mean changing the main global konstant ratio map, but doing this off sets all the map load axis and can take days of logging to rescale and get correct and will cost £100s.
AUM ARZ AUM ME7.5 ecu
These ecus allow just for the injectors to be fitted and just one map to be changed. The map KRKTE which means constant factor (K) for air flow (RK) to injection time (TE) just by changing this one map in the correct ratio to the injector size will allow the fuel to be near enough 100% bang on,  The only other time the KRKTE map should be changed is when running a 4bar fuel reg, I would say 99.9% of all tuner who are mapping car with 4bar fuel regs are not doing changing this map which lead to high fuel trims and loss of power due to too much fuel lower down in the rpm range.... :wink:
So dont just go and fit a 4bar reg... it wont work right unless its been added in the mapping (check with your tuner that the KRKTE is set for a 4 bar reg.
 A lot of the Seat 1.8t boys are just wacking 4bars reg on there car and making less power.. :smug:.  Going for 600cc+ injectors then a few more map need to be chnaged to get it bang on.
In theory.. a cheat just by adding 30% bigger injectors and MAF will give 30% more load request which could work out to be around to 30+bhp with just stock mapping.  It wont kick like a remap and the N75% mapping wont change enough and the load map in the ecu is still on a linear scale.
I hope this helps.. :laugh:  sorry to bore you all :nerd:
« Last Edit: 04 June 2011, 21:15 by RTechUK »
 01455 617233
« Reply #9 on: 04 June 2011, 21:43 »
No much appreicated now know a bit about injectors and maping for the AGU now !  :evil:
