Author Topic: HELP!!!!!!!!!! SUBFRAME REMOVAL  (Read 6986 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« on: 02 June 2011, 20:21 »
ok disaster has shruck was fitting new wishbones and bushes was on me last one and last bolt.
well was tapping the front wishbone bolt throught when all of a sudden it went right throught  :cry: so i think the bolt on the subframe has come off must of been a real weak weld  :angry:.
so i think a new subframe is needed  :sad:.
any diagrams on how to change a subframe and where the best place to put me axle frames for safety as its a must.
Offline andc1
Re: HELP!!!!!!!!!! SUBFRAME REMOVAL
« Reply #1 on: 02 June 2011, 20:35 »
undo steering rack, drop link, undo 4 main bolts and it will fall on your head
Offline (shakey)
« Reply #2 on: 02 June 2011, 20:50 »
hahahahahaha hope not  :smiley:
but thats all there is to it.
Offline houston
« Reply #3 on: 02 June 2011, 20:53 »
yup, and the captive nut youve loosened is a very common problem
Offline (shakey)
« Reply #4 on: 02 June 2011, 21:00 »
o right well i didnt know it was a common problem thought i just fcuked up  :embarassed:.
will the axle stands be safe on the place you put the death trap jack you get off vw ?
Offline Steve_PD
« Reply #5 on: 02 June 2011, 21:26 »
put the axel stands on the chassis rails under the car. big rectangle rail running front to rear just inside the sill
instead of buying a new subframe cant to just get a new captive nut inserted or weld a new one in place
Offline (shakey)
« Reply #6 on: 02 June 2011, 21:37 »
i know where you thats where i put them know just wasnt sure if it was safe enough to get under the car where you said.
dont think there is no way to get in to the subframe to put a new captive nut on.
Offline Steve_PD
« Reply #7 on: 02 June 2011, 21:44 »
:huh:
its not where you put the widowmaker
chassis rail is about 3" inwards
Offline (shakey)
« Reply #8 on: 02 June 2011, 22:09 »
:huh:
yea  i know where you steve like you said its like a rectangle box running back just the right size for the axle stands to sit on.
