Author Topic: 1.8 driver  (Read 1189 times)
Offline wolfsMK3
1.8 driver
« on: 30 May 2011, 00:54 »
hey peoples,
i have a over heating issue i not sure how to fix current replaced rad and thermosate but still bubbles up out of header tank :(
took out thermosate and have same prob, any ideas???
Dan
Offline mwep201081
Re: 1.8 driver
« Reply #1 on: 30 May 2011, 06:34 »
the system probably needs bleeding.......or it could be head gasket
ensure there is no air in the system first.....
Offline LowlifeDubber
Re: 1.8 driver
« Reply #2 on: 30 May 2011, 07:21 »
Is the fan kicking in an out when it gets over 90-100?
It could possibly be an air lock so try running it without the header tank cap on for a bit.
Could also be a knackered waterpump,is it making any unusual noises?Could be that the vanes on the impeller have deteriorated over time and your not getting enough flow.
If it turns out to be a head gasket and your head is buggered give me a shout as i have a complete head for a 1.8 driver you can have for nowt.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: 1.8 driver
« Reply #3 on: 30 May 2011, 08:37 »
I agree,  Head gaskets are quite tough on the 1.8 engines so i would make sure the water pump is good first,  personally at this point i would just replace it, drain and refill the system. Try again.  With the stat and rad being changed, that's the last thing to try before looking down the head gasket route.  But the water pumps commonly fail,  so well worth swapping it.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline wolfsMK3
Re: 1.8 driver
« Reply #4 on: 03 June 2011, 22:32 »
thanks guys, drianied bleed out system and new header cap and so far all is normal :)
