Author Topic: headgasket change- anyone have a guide?  (Read 12518 times)
Offline Lee_dub
Black mk1 2.0 16V - woop
Offline RyanVW
Re: headgasket change- anyone have a guide?
« Reply #11 on: 01 June 2011, 00:19 »
eugh that looks complicated, cant i just mark it up and put it back in the same position?
« Reply #12 on: 01 June 2011, 08:43 »
timing belt purchased head gasket purchased... ill let you know how it goes this weekend  :smiley:
Good luck :afro:
Offline Guy
« Reply #13 on: 01 June 2011, 18:02 »
best of luck with this  :smiley:
Offline RyanVW
« Reply #14 on: 01 June 2011, 21:51 »
what spline bit do i need for the head bolts? m12?
Offline Sam
  • Sam I am
« Reply #15 on: 02 June 2011, 00:10 »
Yes you can  :smiley:
If its the same as a mk2 then yes. Also you need to replace these bolts as they are stretch bolts. Also make sure you work clean.
Offline SoundillusioN
« Reply #16 on: 02 June 2011, 13:01 »
good luck with this.... make lots of clear marks when doing the belt and try not to move things too much once the belt is off.  But then as long as you have marked up all the wheels and pulleys positions you can't go too wrong...
Offline Sam
  • Sam I am
« Reply #17 on: 02 June 2011, 15:26 »
Unless you run a NHS style operation and casually leave random tools/rags/parts inside the bores  :grin:
« Reply #18 on: 02 June 2011, 16:06 »
You been round my place recently then!?  :grin: Or are you talking from experience?
Offline Guy
« Reply #19 on: 02 June 2011, 16:20 »
or chopsticks.. eh Horney?  :lipsrsealed:
