Author Topic: ABS ECU - 8v / 16v the same?  (Read 5879 times)
Offline iyrix
Re: ABS ECU - 8v / 16v the same?
« Reply #10 on: 27 May 2011, 22:54 »
Mines a 97 16v and it does have EDL ,think all valvers of this age have it ,although mines not working at the mo due to a wheel sensor that needs replacing ha, :grin
Dragongreen ,sounds like your module is buggered,pretty unlikley all sensors and pump have gone at the same time :shocked:
strange, i wonder what it would be on the info sticker...  I guess it might have EDL.  The ECU i have is the same number as some in the VR6
Golf GTI 16v
Offline Screech16v
  • MK3 20vt AGU
« Reply #11 on: 27 May 2011, 23:02 »
I thought my module was up the swany so bought one off ebay off a vr6 (so they said) and low and behold it would not go on ,if you can find one with the exact same id number should be fine  :smiley:
Offline iyrix
« Reply #12 on: 27 May 2011, 23:11 »
yeah, well im going to go by PN now.  They look the same as well.
Golf GTI 16v
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #13 on: 27 May 2011, 23:15 »
Yeah thats what im thinking iyrix does make sense as the brakes are still quite good just very obvious no abs is working and as you say EDL as spins quite easily 1st 2nd  :grin:
Im not sure, basically some of the faults that i have change.  so that leads me towards the ECU.
But finding out which ECU i need is a pain.
Yeah i feel your pain i havn't seen another pump itself with same part number as mine think i will just try ecu /module off a 96-98 model im sure it will be the same then  :undecided:
Offline iyrix
« Reply #14 on: 27 May 2011, 23:18 »
I've found this... So if you know your chassis number...
3A0 907 379 A has changed to 3A0 907 379 C and is for cars up to chassis wvwzzz1HzVW123000 (approx 07/96 production).
3A0 907 379 E has changed to 3A0 907 375 A and is for cars from chassis number wvwzzz1HzVW123001.
Golf GTI 16v
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #15 on: 27 May 2011, 23:25 »
There are numerous ECU's across the entire 8v and 16v range/ years so it's not just a case of sticking any old one in there for it to work properly.
As mentioned the 16v's have EDL which is a primitive version of traction control, it only works at speeds over approximately 15mph I believe and simply utilities the ABS system to slow down the particular front wheel that is spinning faster than the opposing side. It's not great but it's better than a kick in the nuts I guess.
« Reply #16 on: 27 May 2011, 23:25 »
EDL was standard on all valvers and vr's I believe
  • my golf gti mk3
« Reply #17 on: 27 May 2011, 23:27 »
This is good to know nice one looks like i should be looking for either part number of the latter choice cheers mate
Offline iyrix
« Reply #18 on: 27 May 2011, 23:28 »
yeah i think we are after the same..  im in touch with a breakers tomorrow.  will let you know what they have.
Golf GTI 16v
Offline iyrix
« Reply #19 on: 28 May 2011, 15:16 »
I've found loads that have the part number 3A0 907 379 D on the ECU.
Does anyone know if this will work?  Mine is 3A0 907 379 E
Golf GTI 16v
