Author Topic: I think I have overfilled with oil - only by abit though. UPDATE WITH PIC  (Read 2937 times)
Offline mac456
Is it worth getting it drained!?
its not too much more. its by the top groove?
so you have the lower groove. then the marking in the middle and then the top groove, the oil is by the top groove.
What shall i do?
Thanks
Mac
« Last Edit: 27 May 2011, 20:30 by mac456 »
Offline richw911
I would drain it tbh.
Wont do the cat any good.
I slightly overfilled my 1.8T once and it smoked at start up  :smiley:
Offline andc1
 :undecided: :undecided: :undecided:
Offline mac456
Offline mac456
Thanks, This is the one thing I have never understood about the 1.8t the dipstick.
What on the dipstick is max mark, is it the top kink?
Will i need a new sump plug when I drain it?
Yeah Its hasnt smoked yet and I have done about 150miles in it since.
« Last Edit: 27 May 2011, 19:17 by mac456 »
Offline richw911
Im not sure how much it has over filled from what you describe  :undecided:
If it is only very slight it will be ok.
Offline steve113
undo the oil filter and let some drain out  :wink:
Offline mac456
I am going to re check in a min once it has cooled down and I will try and get a picture.
The oil was by the top kink, is that the max mark?
Offline mac456
Im going to a garage tomorrow to get the pads done, so ill probably just get them to do it
Offline thatwillis
Random I know but you don't have a big syringe around do you?.... ok probs only me that does.... but you can push it into the dipstick tube and because its taped it seals and you can suck the oil straight out  :smiley: Or a long tube and a small drill pump or something. Ether way you can use the dipstick tube as access.
