Author Topic: Very Worried over A4  (Read 2855 times)
Re: Very Worried over A4
« Reply #10 on: 25 May 2011, 20:27 »
Could be the oil pick up pipe blocked, I got lucky and caught mine in time.
Offline AudiA8Quattro
« Reply #11 on: 25 May 2011, 21:12 »
I think the same, pick up pipe, its a common problem.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #12 on: 26 May 2011, 16:50 »
It is common as said,  Make sure you use the revised oil filter... its the size of a tractor filter, is £5.00 from TPS or £8.50 ish genuine list price, depending on if you have a TPS,  the idea is to increase the engine oil capacity a bit,  3.5l isnt enough and it turns to sludge to quickly, then change the oil using the correct grade and ONLY Fully synthetic every 5-6k miles to prevent problems in the future.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
