Author Topic: 4wd 150?  (Read 8503 times)
Offline Kerrse
Re: 4wd 150?
« Reply #10 on: 26 May 2011, 10:38 »
Remember that the 150's tend to suffer with an expensive cam eating problem!
Depends on the oil i would say, i always use Castrol Edge turbo diesel cost me £40-50 every service but not had any cam problems so far and gone over 120k.
Re: 4wd 150?
« Reply #11 on: 26 May 2011, 13:32 »
Go for a 130bhp and remap it.
Offline yamz89
Re: 4wd 150?
« Reply #12 on: 26 May 2011, 21:42 »
Well I was hoping to aim for the brighter side of 200bhp, and seeing as the 150 has the bigger turbo, uprated injectors and a front mount inter cooler as standard, it makes more sense to go for the 150 as the 130 would require alot more work and money, though I do see your point of the reliability of the 130, its just I doubt a remap to 170 bhp in a diesel would keep me occupied for very long.
The other car that I was looking at was the (and yes I'm about to say the B word) E46 330d, and get that remapped.
71' Beetle in Marina Blue
05' Octavia vRS
10' Golf GTi
Re: 4wd 150?
« Reply #13 on: 27 May 2011, 00:21 »
I believe a 130 will remap really well, plus I believe from threads on here it can sometimes make a little more torque.
Daft idea, turbo problems, swirl flaps fail and can write the engine off, they need lots of looking after.
« Last Edit: 27 May 2011, 17:26 by Wayne »
Offline yamz89
Re: 4wd 150?
« Reply #14 on: 27 May 2011, 09:23 »
How do you find your MK1 VRS on fuel? A mate used to have a red one that was remapped my awesome, that was quick.
05' Octavia vRS
10' Golf GTi
Re: 4wd 150?
« Reply #15 on: 27 May 2011, 17:26 »
For the power etc, it is very good, doing around 30mpg in mixed driving, will hit 40mpg on a run.
Offline yamz89
Re: 4wd 150?
« Reply #16 on: 27 May 2011, 20:23 »
Quote
Done a bit of research, I found out the turbo failures were down to the oil feed pipes becoming blocked and these should be checked every other year, and the swirl flaps are easily removable. There are actual companies out there who manufacture blacking caps to irradiate this problem - http://swirlflaps.co.uk/index.html
05' Octavia vRS
10' Golf GTi
Re: 4wd 150?
« Reply #17 on: 27 May 2011, 21:10 »
Quote
I know the swirl flaps are easy to sort but they do tend to suffer turbo failures.
Offline harry bum
Re: 4wd 150?
« Reply #18 on: 29 May 2011, 16:06 »
get a 150 with good service history and you'll be fine, ppl buy 130's when they ca'nt afford 150's simples
