Author Topic: ko3 ko3s outlet manifold  (Read 1127 times)
Offline matping
  • MK1 20vT MK5 GTI T
« on: 23 May 2011, 19:22 »
just trying to find out if the turbocharger outlet manifold for a ko3 fits a ko3s?
ive called it the outlet manifold as im not sure what its called its not the exhaust mani its the 1 with the 3 studs on for the turbo downpipe to connect to
Offline 20v
Re: ko3 ko3s outlet manifold
« Reply #1 on: 23 May 2011, 20:31 »
yer they fit mate only fing different is turbo intake pipe
Offline matping
« Reply #2 on: 23 May 2011, 20:45 »
ok pal do you know much about shaft play im not sure if the turbo needs rebuilding theres play in the shaft left to right and front to back theres not much left to right  i think oil pressure will take that up im just botherd about the front to rear
Offline Dave_IOW
« Reply #3 on: 23 May 2011, 21:54 »
end float (in and out) is the one you want to be careful of, a competant mechanic will be able to advise you   :wink:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline matping
« Reply #4 on: 23 May 2011, 22:01 »
got the ko3s really cheap  60 quid  the outlet manifold has many cracks i dont know why this is ??? its asif its got to a really hot temp  i have anouther mani for it tho off a ko3  i will put that on to solve that problem then i think ill take the turbo to r-tech to get them to have a gander ! dave i also gave someone your num he has a  agu head  im not sure if he got intouch
Offline Dave_IOW
« Reply #5 on: 23 May 2011, 22:06 »
ah ok cheers pal, im all sorted now though!  :wink:
Offline matping
« Reply #6 on: 23 May 2011, 22:08 »
you got any ideas why there was so many cracks on the turbo manifold outlet  worries me a bit  :cry:
Offline Dave_IOW
« Reply #7 on: 23 May 2011, 22:11 »
if you mean the exhaust housing on the turbo its probably because they didnt let it cool down?
Offline matping
« Reply #8 on: 23 May 2011, 22:13 »
ok bud ill get it sorted  cheers for the info :smiley:
