Author Topic: Gti 2E engine problem  (Read 19697 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Gti 2E engine problem
« Reply #30 on: 26 May 2011, 17:05 »
No, there is an O-T mark on the camshaft,  that speaks for its self,  the crankshaft doesnt have any marks on it,  so you put the alternator pulley back on, and use the little notch on that to line up with the little dot on the intermediate (dizzy) pulley
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Rmachines
« Reply #31 on: 26 May 2011, 17:13 »
Paint the cutout on the pulley with tipex or something similar,  same on the AUX Sprocket, makes it easier to see!!
Offline dansmk3
  • FULL TIME JUNGLIST
« Reply #32 on: 26 May 2011, 18:25 »
great, i will do that tomorrow as right now have got horrific thunder storms.
i will say that on my aux pulley i do have the OT mark. the aux pulley does look just like the cam pulley you know!
well i will try the dot on the aux with the notch cut out on the crank! fingers crossed it will fire up all sweet.
Offline dansmk3
« Reply #33 on: 27 May 2011, 12:35 »
just thought id show a couple of pics of the bottom end before and after cleaning lol
Offline Rmachines
« Reply #34 on: 27 May 2011, 15:22 »
yuk that was a bit gunky
Offline dansmk3
« Reply #35 on: 27 May 2011, 15:31 »
Yup lol
Right everything is timed up spot on! (Even made markings on the engine to make sure!) But she still don't wanna kno!  I'm kinda hopin that coz iv kinda damaged the rotar arm a min ago this could be why! Lol! And I'm also going to fit a new temp sensor!!
Offline Rmachines
« Reply #36 on: 27 May 2011, 16:45 »
Fit a new rotor arm and try again, temp sensor wont be the cause of this problem, although it doesnt mean it doesnt need replacing!
Now its all timed up as per cambelt alignment,  Double check that the dizzy rotor arm is lined up, just coz the aux shaft is lined up with the cam and crank, doesnt mean the dizzy hasnt been turned, to check the dizzy rotor arm points to the little notch on the dizzy body.  Fingers crossed  :smiley:
Offline dansmk3
« Reply #37 on: 27 May 2011, 16:52 »
When it was all aligned correctly the dizzy was out! That's how I broke my rotor arm tryin to remove the dizzy! But got dizzy out and the rotor arm lines up with the little cut out! So all I gotta do is fit nrew arm and see what happens!!
Offline dansmk3
« Reply #38 on: 27 May 2011, 18:07 »
aqnd still dead!!! she dont even wanna kick into action now!!!!  :angry: :angry: :angry: :angry: :sick: :sick: :angry: :angry: :angry: :angry:
Offline dansmk3
« Reply #39 on: 27 May 2011, 18:13 »
right here is a pic of the crank and aux lined up
and here is one of the aux sprocket with the ot marks on it  :huh: :huh: :huh:
