Author Topic: Drive Shaft Removal  (Read 5530 times)
Offline AudiA8Quattro
Re: Drive Shaft Removal
« Reply #10 on: 24 May 2011, 17:08 »
As mr h says you have done everything so the only way of sorting it is with brute force
Absolutely not. All that will happen is you will do lots of damage.
Buy a hub puller  :smiley:
« Last Edit: 24 May 2011, 17:15 by AudiA8Quattro »
Offline Sam
  • Sam I am
« Reply #11 on: 24 May 2011, 17:12 »
Absolutely not. All that will happen is your do lots of damage.
I have one, it looks like this -
Offline madmanluke
« Reply #12 on: 25 May 2011, 12:55 »
hmm... Ok Il work it out. What do hub pullers usualy retail for? considering they are coming off, being painted, then going onto a different subframe probably in the same day, I dont really want to spend much on it!
