Author Topic: Ignition problem  (Read 1706 times)
Offline losthaplot
Ignition problem
« on: 29 March 2005, 17:03 »
Hey ppl,
I have an ignition problem on my mk3 1.4 golf,
To start the car I have to hold the key very tight pushing with abit of force and as quick as possible turn the key, if not done right it will not turn on .. It causes alot of problems as I never get it right the first couple of times and gets annoying after a while..
Anyone know how I can solve the problem??
Regards
I Was Someone, But Now I am Someone That Became Someone And Will Make Someone, Someone.
576
Offline insane
Re: Ignition problem
« Reply #1 on: 29 March 2005, 17:47 »
hey mate, sounds very similar to the problem i had,
all that was needed for me was a new ignition switch, £10 from my local store
check this thread for some more info
http://www.golfgtiforum.co.uk/index.php?topic=16055.msg145118#msg145118
hope this helps
many thanx
Ben
Offline bosun
« Reply #2 on: 30 March 2005, 09:39 »
100% ignition switch (Not the barrel).Common fault.
Offline losthaplot
« Reply #3 on: 30 March 2005, 17:38 »
where did you pick up your ignition switch m8?
regards
576
Offline insane
« Reply #4 on: 30 March 2005, 17:56 »
I got mine from http://www.vwandaudi.co.uk/ which is local to me, should be able to mail order it from somewhere though
 :smiley:
