Author Topic: sensor housing on front of engine  (Read 692 times)
Offline polo6n222
« on: 17 May 2011, 11:18 »
mine is leaking where it joins the block is it a gasket or a o ring or do i need to buy a new housing 2.0 8v
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: sensor housing on front of engine
« Reply #1 on: 21 May 2011, 21:58 »
Yes new housing and new o-ring, very common problem, also check the one on the side of the block.  They are very cheap on ebay and only take 10 mins to swap.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
VW BUSH
« Reply #2 on: 22 May 2011, 01:58 »
Paid £10 for one at ECP, make sure it has a plug though :wink:
