Author Topic: No Spark No more CLUUUES  (Read 2005 times)
Offline dashey
Re: No Spark No more CLUUUES
« Reply #10 on: 16 May 2011, 22:46 »
The crannk position sensor is in all the way all earths are fine ht leads coil pack fine when you turn the ignition on you get a test spark but thats it when its cranked over no spark also theres no fuel pump which made us point at the relays and ecu they have been changed and it still dont work we are lost hence why it has been put on here thank for your help though and any more answers please dont hesitate as wana get this sorted lol
Offline neil1780
« Reply #11 on: 16 May 2011, 22:53 »
Is there no prime from the pump when you turn the ignition on then?
V6 4MOTION
Offline dashey
« Reply #12 on: 16 May 2011, 23:58 »
No nothing the fuel pump isent getting a signal to prime
Offline neil1780
« Reply #13 on: 17 May 2011, 00:04 »
When you say the loom has no immobiliser has there been an aftermarket one fitted? has it not been removed properly ie cut wires not been rejointed correctly and have came loose?
not much else to try mate other than the ecu itself.
V6 4MOTION
Offline dashey
« Reply #14 on: 17 May 2011, 00:19 »
I pm'd you but was ment to reply im gona blame the tirdness but yeah changed ecu transponder n chip  n still nothing n the wiring where the imboilser was is fine
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #15 on: 17 May 2011, 21:36 »
EFI Main relay?  AKA ECU Relay?  i believe desperate to fuel pump relay on the golfs,  unlike most EFI systems
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline dashey
« Reply #16 on: 17 May 2011, 21:41 »
I tryed relays but still no hope
