Author Topic: engine stalls when coasting to a stop ?  (Read 2448 times)
Offline trog_nfs
Re: engine stalls when coasting to a stop ?
« Reply #10 on: 16 May 2011, 22:35 »
check the vacuum hose that goes to the ECU, as this is where the  MAP sensor lives. Hose perishes etc etc
Offline spudboy6
  • Just like a golf ......
« Reply #11 on: 19 May 2011, 13:37 »
theres a black box on top of the cam cover under this is where the breathers connect to looks like a disc or flying saucer shape.
02 sensor is lambda fault
speed sensor is crank sensor fault i think. worth checking this to see if the wires are brittle or brocken.
I don't see this ? All I see is my dizzy on one end the cam belt cover on thee other end and my airfilter housing with a crank breather ? Am I just being thick and missing it ?
Offline m3vwg
« Reply #12 on: 19 May 2011, 19:46 »
black square box on top of rocker with two rubber pipes comming out,unscrew the two screws pop black box off and the saucer is underneath :smiley:
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #13 on: 19 May 2011, 21:47 »
Agree, seems like your crank sensor is causing your stalling issues, had similar on my old 16v, wires had corroded.
