Author Topic: VCDS Errors - Can you help me clear them?  (Read 8350 times)
Offline oldman
Re: VCDS Errors - Can you help me clear them?
« Reply #10 on: 13 May 2011, 21:26 »
Hi Buck       Re your telephone install. I have the same module and had similar faults,try the following it should delete most if not all.
Byte 3-Dianosis antenna,change to 01
Byte 6-Control unit,        change to 01
Good Luck     Rob
Offline Buck
  • Das Auto
« Reply #11 on: 13 May 2011, 21:32 »
Thanks Rob - will give that a go too!
Offline mortygt140
« Reply #12 on: 14 May 2011, 16:40 »
Adrian if you have still got the VCDS cable change the 1 in 00000100 byte 18 to a 0 that will sort the a errors out once you have the original bulbs in your reg plate lights.
For the bluetooth did you delete the faults once every thing was fitted?  if they came back up then go through the coding in the long coding helper most of it is self explanatory but if you get stuck post up what your having problems with and ill look in later.
by the way if you have a problem with stuff like the audio faults then just 00 them out on the byte,
The load management is to do with low battery, the central electrics module shuts none essential components down to save the battery totally draining once you have deleted all the faults it will delete itself.
Darren :smiley:
Offline Buck
  • Das Auto
« Reply #13 on: 14 May 2011, 23:05 »
Thanks Darren
This'll be tomorrow's job!
I'll run another scan tomorrow and see if any others have cropped up -hopefulyl will be all clear
