Poll
oil light flashing non stop i dont know what to do
problem?
1 (100%)
how to repair
0 (0%)
Total Members Voted: 1
Author Topic: Need Help!!! Oil Light Buzzing Non Stop  (Read 844 times)
Offline gee_turk
« on: 12 May 2011, 19:14 »
iv changed both the pressure switchs the blue one and white one done a full service taken the sump off then unbolted the oil pump cleaned it properly the shaft spins ok and when its got oil inside and you spin the shaft it pushes it out the other end but still as soon as you go over 2000rpm the light flashs non stop someone please help me im baffed.
Offline gee_turk
Re: Need Help!!! Oil Light Buzzing Non Stop
« Reply #1 on: 12 May 2011, 19:16 »
the golf is a mk3 1.8gl
Offline trog_nfs
« Reply #2 on: 12 May 2011, 19:59 »
have you had it pressure tested?
Offline gee_turk
« Reply #3 on: 12 May 2011, 20:51 »
yeah its ok the car runs lovely not a single knock and and very smooth
« Reply #4 on: 12 May 2011, 21:35 »
Fit a gauge and see if the pressure is low, if not you have a faulty sender.
Offline gee_turk
« Reply #5 on: 12 May 2011, 23:35 »
its sorted at last its a bit late but i came up with an idea of swopping the switchs around as i just bought the car i put the white switch at the top and blue one at the bottom and the awefull buzzer has gone and ther light is off  :grin:  i had a bit of idle problem i adjusted that aswell fingers crossed all problems are solved thanks for all your ideas.
