Author Topic: TDI Woes - DPF and Coil warning lights  (Read 39142 times)
Offline The Doc
  • E63s Estate - Vito Sport
Re: TDI Woes - DPF and Coil warning lights
« Reply #10 on: 13 May 2011, 22:44 »
but I've not tested in 1st / 2nd, but I will if the fecker will stay on the dyno  :grin:
you need ballast for that  :wink:
 let me know when your need me  :smug:
Thank you sir, I think we'd balance it out great  :grin:
Offline Andoni
« Reply #11 on: 13 June 2011, 21:24 »
hi all,
just a note to say VW did the work.
they done a regeneration on the DPF and ran a software update on the ECU. now the car performs so much better. it feels as though the update has corrected the issues with the slight auto throttling when using the clutch, and the gear changes are a lot smoother.
all under warranty thankfully.
Offline The Doc
« Reply #12 on: 13 June 2011, 22:49 »
hi all,
Great news mate  :wink:
