Author Topic: Anyone ever out those LED strips in a headlight?  (Read 3483 times)
Offline Jack3559
Re: Anyone ever out those LED strips in a headlight?
« Reply #10 on: 10 May 2011, 23:11 »
Can you not just tuck a little orange bulb into the headlight?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #11 on: 10 May 2011, 23:13 »
Quote
Indicators on your wing mirrors maybe?
They'd be classed as the side repeaters though, wing mirror indicators are fine if you decide to delete the standard wing located indicators but will not suffice for the front bumpers ones as well. Id say modified headlights is definitely the way to go with this.
Offline jonnypolish
  • t2871r needed :)
« Reply #12 on: 10 May 2011, 23:15 »
I missed the point  :embarassed: thought he only needed side repeaters :(
Its definitly not possible to fab up a small section in the light for the bulb?
If not i can't really see any other options to LED strips ?
 MK2 VR y0!
Offline Jack3559
« Reply #13 on: 10 May 2011, 23:17 »
Actually... Considering the lens isn't clear a strip may not look too bad.
« Reply #14 on: 10 May 2011, 23:19 »
I don't think it'd be too difficult to drill a hole and dremel some slots in one of the headlight chambers and insert an indicator bulb holder.
« Last Edit: 11 May 2011, 00:20 by thai-wronghorse »
Offline Bellend
« Reply #15 on: 11 May 2011, 00:15 »
Cheers guys. Ahead of you with the bulb holders, I did it on my old headlights but they weren't bright plus an MOT fail because the bulb or reflector wasn't clear enough. So was thinking LEDs.
As Jack said it's not too clear so think I could get away with some very bright,decent LED strip and if it looks gash just tint it to blend in.
Cheers for the views though, reckon it would be visible if I put it along the bottom and round the side of the reflector, behind the glass?
Thanks.  :smiley:
Where all my moneys went.
« Reply #16 on: 11 May 2011, 00:22 »
If you were to uprate the lighting loom to start with then stick some decent quality chrome look / orange flashing bulbs in then surely they'd be bright enough for indicators?
Offline LowlifeDubber
« Reply #17 on: 11 May 2011, 07:34 »
Your car should fail it's MOT without side repeaters unless obviously you know the tester doing it?
Just thinking the same, they are a legal requirement as I know the same question was asked in the mk2 section.
My brothers my mot tester :evil:
However if i get pulled more than once i will add something discrete in the wing mirrors that you cant see unless it's flashing.
Luvin your front bumper now Bellend.Good work! :cool:
Offline Jack3559
« Reply #18 on: 11 May 2011, 11:42 »
Would be best/coolest/most oem/least chavvy way of doing it!
 :cool:
« Reply #19 on: 11 May 2011, 12:22 »
It's how im planning on doing it anyway.  :wink:
