Author Topic: New to VW!! Help needed asap on gearbox repair quote!!!!  (Read 1675 times)
Offline d4v1dy0n
Bought my first golf mk 4 gti 2.0 about a month ago, thought it was the bees knees.  Only to find out after a couple of weeks that gearbox is fooked!!
Common problem, drive shaft ceased, rivot popped out causing it to tear through bell housing.
Car bin taken to garage for repairs and funnily enough as i guessed, they got back with an expensive quote.
I've bin quoted £1200 for repairs, thought it was for a new gearbox but wasnt was a recon!!!
Not sure wot it usually costs for a gearbox repair but ive had a look online a recon costs around £300 on average from ve breakers in my area, there it seems they're charging £800 - £900 for labour charges!!!  Thought it was abit expensive for a days work!!
Could do repairs myself but no equipment and nowhere to carry out work as i park in street outside my house.  Hence reason i took it to garage..
Just wanted to know whether this price is about right or should i do a runner and find somone to do it abit cheaper!!
Need help asap please, need my baby back!!!!!!
V-Dub Dave
« Last Edit: 06 May 2011, 21:45 by d4v1dy0n »
Re: New to VW!! Help needed asap on gearbox repair quote!!!!
« Reply #1 on: 06 May 2011, 22:03 »
Do a runner, get a s/h box and find a cheaper local garage to fit it also worth fitting a new clutch kit whilst it is apart.
Offline d4v1dy0n
« Reply #2 on: 06 May 2011, 22:13 »
nice one!!
Was thinking that, just got another quote for 650 gearbox plus fitting - mobile mechanic?!?!?!!
Said he could do it cheaper if i sourced gearbox!!!!
Any idea where i could find a s/h cheaper than £300 anywhere??
Not many breakers close to swindon!!
Offline d4v1dy0n
« Reply #3 on: 06 May 2011, 22:15 »
clutch was done just before i bought it, was guessin i need it replaced now anyways!!
is this right??
« Reply #4 on: 07 May 2011, 00:27 »
is this right??
In that case it should be ok, but if you were to refit it and it started slipping in a month your going to end up doing the same job.
The choice is yours.
Offline d4v1dy0n
« Reply #5 on: 07 May 2011, 11:07 »
ok cheers!!!
