Author Topic: 91' 8v gti disc brakes, size??  (Read 15286 times)
Offline newlad
Re: 91' 8v gti disc brakes, size??
« Reply #10 on: 06 May 2011, 21:47 »
well, thanks all for the good advice, sorry if i started a bit of a war, as my calipers are in good shape, but my wallet aint, i'm just gonna go for some standard size drilled and grooved discs,
thanks again :smiley:
« Reply #11 on: 06 May 2011, 21:53 »
Better to fit good quality pads on standard discs.
Offline mwep201081
« Reply #12 on: 06 May 2011, 22:30 »
What ever you do don't take advice about brakes from someone who's driving a 150BHp+ motor with drilled discs on the front and drums on the back
Offline Neo Badness
  • Feet are for pedals
« Reply #13 on: 06 May 2011, 23:06 »
+1.
 Save the cash then and just renewing your brake hardware with OEM stuff will make a tangible difference.
Offline Neo Badness
« Reply #14 on: 06 May 2011, 23:08 »
Rear brakes don't really do much other than keep the car in a straight line. Drums on the rear working properly on a light car are perfectly acceptable.
« Reply #15 on: 07 May 2011, 00:28 »
Yep spot on, well set up drums are fine.
Offline mwep201081
« Reply #16 on: 07 May 2011, 07:15 »
The rear drums on a 1.3 are renowned for being sh!te. They are prone to fade , which you DO notice when braking from 70, which is why I put a mk3 gti axle on my 1.3...the difference is most definitely tangible, with every MOT inspector for the past 4 years commenting on the performance of the brakes.
Offline newlad
« Reply #17 on: 07 May 2011, 19:28 »
my gti's got discs on the rear anyway, standard but in good nick,
thanks all
Offline newlad
« Reply #18 on: 07 May 2011, 21:25 »
anyone know where the best place to buy discs and pads from is? cheers
Offline Neo Badness
« Reply #19 on: 07 May 2011, 21:32 »
A shop? Sorry, couldn't resist.
Seriously though try your local motor factors. Or eurocarparts are decent and have a 15% off pads and discs at the mo'
http://www.eurocarparts.com/brakes
HTH's
