Author Topic: h4 bulbs for mk2  (Read 2461 times)
Offline mk2bal
h4 bulbs for mk2
« on: 02 May 2011, 19:30 »
what bulbs are the best for mk2's? been looking at philips h4 extremes and vision plus.. can see the extremes are more expensive, so im guessing brighter. i wouldnt mind something bright and white, but not too keen on a blue or yellow look. what can you lot vouch for?? also just to add, ive already got an uprated loom kit.
Offline dragonfly
Re: h4 bulbs for mk2
« Reply #1 on: 02 May 2011, 20:05 »
Osram Nightbreakers and Ring Max 100% are 2 I have used with an uprated loom on my mk2.  Recommend either of them.
Offline Neo Badness
  • Feet are for pedals
« Reply #2 on: 02 May 2011, 20:08 »
Got night breakers. not too shabby. Had phillips ICE white ones whatever they were called and the were pretty good.
Offline richking
« Reply #3 on: 02 May 2011, 22:56 »
Are the uprated looms any good? do they work?
Offline sprout99
« Reply #4 on: 03 May 2011, 08:05 »
all it does is put spots on a designated supply rather than shared
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline dragonfly
« Reply #5 on: 03 May 2011, 08:44 »
Yes they do - a cost effective upgrade.  More info here: http://www.matey-matey.com/uprated_headlight_wiring.shtml
Offline mk2bal
« Reply #6 on: 03 May 2011, 09:41 »
Mine doesn't have anything to do with spots (as I don't have spots). It gives the headlights a dedicated supply from the battery so they can draw the current they require. The old feed becomes the trigger wires for the relay
Offline sprout99
« Reply #7 on: 03 May 2011, 09:54 »
i made my own - left headlights alone and wired spots through deignated supply though relay
Oak green mk2
V50 D5 Sportwagon
Offline dubber36
« Reply #8 on: 03 May 2011, 11:41 »
Surely dip needs improving as much as main beam?
Offline sprout99
« Reply #9 on: 03 May 2011, 11:44 »
mine was ok until put mains on then the lot dimmed badly
Oak green mk2
V50 D5 Sportwagon
