Author Topic: mk3 golf gti 8v keeps cutting out?  (Read 5947 times)
Offline asho
Re: mk3 golf gti 8v keeps cutting out?
« Reply #10 on: 02 May 2011, 22:54 »
yeh everything seems fine, had read about the bottle cap etc, and seems ok ?
Offline neil1780
« Reply #11 on: 02 May 2011, 23:04 »
If its a cold start problem have a look here mate
http://www.golfgtiforum.co.uk/index.php?topic=188080.0
V6 4MOTION
Offline asho
« Reply #12 on: 02 May 2011, 23:25 »
nice1 mate will try disconnecting my battery overnight, see if that does anything? and will let you no, cheers! :smiley:
Offline dashey
« Reply #13 on: 03 May 2011, 00:52 »
Im not to sure if its the problem you got but this happened to my vr6 it ended up being the head gasket 2 of my cylinders were filling up with water even though there was no signs of it oil was fine still run idled normally no coloured smoke in the exhaust done compression test and all seemed ok baffled me to be honest but changed and fine now so if your mechaniclly minded and can wisk the head off quick to check or know someone that can them recomend changing it
Offline Gash
« Reply #14 on: 03 May 2011, 14:55 »
the water loss could they have refilled the coolant but not blend the system so the water would just seem to disappear. or has it been a while now since it was serviced?
Offline Screech16v
  • MK3 20vt AGU
« Reply #15 on: 03 May 2011, 19:11 »
Good point gash, are your carpets dry mate,maybe leaky matrix :smiley:
