Author Topic: gti front calipers  (Read 1031 times)
Offline nikkiy9
gti front calipers
« on: 02 May 2011, 15:03 »
hey guys, is there much difference between the CL and GTI calipers??
went to bleed my brakes today to find that the bleed nipple will snap if i try to loosen it, so i've bought some GTI's,
will these fit my cuddent discs or will i need larger discs?? also are the location bolts in the same position or do i need to make a new location plate??
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: gti front calipers
« Reply #1 on: 02 May 2011, 15:29 »
If you're going to fit the GTI calipers you'll need the carrier brackets, discs and pads as they're bigger than the CL ones.
Offline nikkiy9
« Reply #2 on: 02 May 2011, 16:06 »
Cheers, any idea where I can get the carrier brackets from?
« Reply #3 on: 02 May 2011, 16:34 »
A breakers yard is your best and cheapest bet.
« Reply #4 on: 02 May 2011, 16:36 »
Failing that there always shed loads of mk3 GTI's been broken for spares on ebay.
Offline nikkiy9
« Reply #5 on: 02 May 2011, 16:46 »
Are all golf hubs the same with the carriers added as extra?
Offline LowlifeDubber
« Reply #6 on: 02 May 2011, 17:59 »
It depends what you currently have on the car atm.If you have 239mm discs then the caliper is bolted straight onto the hub.
If they look like this
Then you currently have 239mm discs which means to get the new calipers to fit you will need a complete hub set up.
They could be 256/280mm discs.
