Author Topic: New suspensi0n.......any ideas?  (Read 1593 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 01 May 2011, 19:53 »
Firstly please excuse my typing but my letter 0 is n0t w0rking s0 having t0 use the digit 0!!
G0lf GTI 8v......
I w0uld like a small dr0p, say 25mm with new sh0cks. Is the best and cheapest way t0 get c0il0vers 0r can I get springs and sh0cks. I w0uld like a c0mf0rtable ride and n0thing t00 l0w.  What is the best.....and als0 what is the easiest t0 fit?
Thanks in advance  :smiley:
Re: New suspensi0n.......any ideas?
« Reply #1 on: 01 May 2011, 21:17 »
Good quality spring and shock kit is the best bet tbh.
Offline neil1780
« Reply #2 on: 01 May 2011, 21:19 »
Upto -35mm shocks an springs will be most comfortable but i would go for coilovers as you may change your mind in the future like i have :smiley:
V6 4MOTION
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #3 on: 01 May 2011, 21:29 »
Thanks guys.....
Any links 0r rec0medati0ns 0n a spring and sh0ck kit that is under £200?
« Reply #4 on: 01 May 2011, 21:31 »
Thanks guys.....
Try Venom or ebay
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #5 on: 01 May 2011, 21:39 »
Thanks guys.....
Try Venom or ebay
Thanks mate.....Will check 0ut Ven0m n0w  :wink:
Offline Ninj
« Reply #6 on: 01 May 2011, 22:12 »
Following this thread with interest cos my front shocks are in need of replacement and I'd rather not go to the expense of coil overs but would like a bit of drop 25-30mm ish while I'm doing it.
Please keep us posted :)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #7 on: 01 May 2011, 22:21 »
The highest they start is 35-40mm then d0wn t0 55-60mm......Still l00king f0r 25-30mm.  This is the best s0 far......
http://cgi.ebay.co.uk/PROSPORT-VW-GOLF-MK3-GTi-SUSPENSION-KIT-40mm-F-35mm-R-/380325060993?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item588d23e181#ht_2642wt_1139
I cant g0 t0 l0w as I my car has my teenage daughters in it, 10st Bullmastiff and I take my car up the w00ds when walking my d0g s0 anything like 40mm will be just t0 l0w  :sad:
Offline Ninj
« Reply #8 on: 01 May 2011, 22:23 »
Yeh likewise, don't need anything like 40mm.  Is there really nothing around 20-30mm?
Offline Mikester
  • Civic Type R
« Reply #9 on: 01 May 2011, 22:37 »
Problem with coilovers if you choose them is that you will keep wanting to go lower.
Issue with shocks and springs is you cant fiddle the height to get the best visually appealing "stance".
Depends if you are doing this for looks or drive i suppose.
