Author Topic: Bad mpg ? Causes  (Read 2021 times)
Offline mani12354
Re: Bad mpg ? Causes
« Reply #10 on: 12 May 2011, 11:14 »
try checking the inlet manifold  cable which runs at the back of it to the ecu, and also give ur throttle body a clean!
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #11 on: 12 May 2011, 11:46 »
Fuel gauges are notoriously ghey on mk3's due to the idiotic fuel tank design.
Offline dom
  • Back in a Mk4
« Reply #12 on: 12 May 2011, 15:19 »
And a poorly designed sender :wink:
Offline spudboy6
  • Just like a golf ......
« Reply #13 on: 12 May 2011, 20:45 »
I've found some fault codes
Co2 sensor -changed
Idle speed sensor ?
Idle speed limit exceeded i think  I'll find exact codes later ,
What do I need to check on that ecu cable ?
Cleaned the tb and mass air flow sensor , changed plugs and air filter and a service still not much better .
