Author Topic: indicator flashing too fast  (Read 3724 times)
Offline local.litw
Re: indicator flashing too fast
« Reply #10 on: 29 April 2011, 22:32 »
cheers for all the tips. there are 2 wires each side which used to go to the fogd but this shouldn't affect it??
Offline dazzawest1987
« Reply #11 on: 29 April 2011, 23:01 »
if the wiring's damaged it could do
Offline local.litw
« Reply #12 on: 29 April 2011, 23:15 »
ok ill have a look. cheers
Offline Leon27
« Reply #13 on: 29 April 2011, 23:26 »
What bulbs are in the front ,if its they are those low wattage ones they may not be drawing enough current therefore fast flashing as if theres a bulb gone :smiley:
Very good point. Check the wattage of the bulb from ebay. Just to confirm, it is only one side that isn't working properly? The one that was hit? If so, check the bulb, then start swapping lamps from the affected side to the working side one by one, front unit, side repeater then rear cluster. hopefully you'll pick up on something there otherwise you will be looking at a power/wiring fault as already mentioned :)
« Last Edit: 29 April 2011, 23:28 by Leon27 »
Offline local.litw
« Reply #14 on: 30 April 2011, 09:23 »
both sides are affected  :cry: I'm going to put the old right one back in and see what happens.
