Author Topic: indicator flashing too fast  (Read 3719 times)
Offline local.litw
« on: 29 April 2011, 20:55 »
Had a ding in my mk3 and smashed one indicator/fog light. I got some new ones off ebay but they are just indicators without the fog lights. when i dialed it all back in all indicators flash too fast. and ideas what is causing this?? also is it an mot failure if they flash fast? cheers
Offline madmanmart
Re: indicator flashing too fast
« Reply #1 on: 29 April 2011, 20:56 »
Indicator bulb not working.........
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline matt_1982
« Reply #2 on: 29 April 2011, 20:58 »
As Mart said above will be a bulb not working mine sometimes does it i just hit it then it works hahaha
Offline brett
« Reply #3 on: 29 April 2011, 21:04 »
snap i had this only the other week lol,had checked them all but 1 d'oh
« Reply #4 on: 29 April 2011, 21:05 »
Yep bulb blown  :smiley:
Offline local.litw
« Reply #5 on: 29 April 2011, 21:30 »
I wish!! all bulbs working good
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 29 April 2011, 21:38 »
What bulbs are in the front ,if its they are those low wattage ones they may not be drawing enough current therefore fast flashing as if theres a bulb gone :smiley:
Offline dazzawest1987
« Reply #7 on: 29 April 2011, 22:00 »
Bad earth somewhere ? Check the connectors to your rear lamps, and check the bulb holders in the lamps
Offline dom
  • Back in a Mk4
« Reply #8 on: 29 April 2011, 22:14 »
I had this when I was tinkering with a set of clocks, it was because i'd soldered some led's in and inadvertently bridged a couple of the wires on the circuit board so it could be an issue with something shorting out on the clocks...although I doubt it :grin:
A very helpful reply from me!
« Reply #9 on: 29 April 2011, 22:17 »
Check the wiring behind your bumper aswell
