Author Topic: 195 tyres instead of 205's ????  (Read 4040 times)
Offline hammonds
Re: 195 tyres instead of 205's ????
« Reply #10 on: 26 April 2011, 22:49 »
had 205's on my 8v with standard rims when I had it. Got 195's on my VR6 currently with the standard highline rims. Both sets were 15inch I believe.
Offline neil1780
« Reply #11 on: 26 April 2011, 22:50 »
Does anyone run 195/40/17?
V6 4MOTION
« Reply #12 on: 27 April 2011, 23:27 »
I did not, but have seen them used all ok :smiley:
Offline Len
« Reply #13 on: 28 April 2011, 12:56 »
195's should be 45 profile.
205 and 215 can be 40 profile.
www.sas.org.uk
www.the-ace.org.uk
Offline whit
« Reply #14 on: 28 April 2011, 17:26 »
i'm wanting to change to 195's purely because they're cheaper!!
what about upping the profile too?? could you go up to a 55 or 60 without a problem?
would they be any cheaper?
Offline tweed
« Reply #15 on: 28 April 2011, 17:35 »
I had 195/55/15 but recommend 50mm wall
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #16 on: 28 April 2011, 18:45 »
The '50' isn't a measurement in milimetres, it's a percentage of the tyre width. And no I wouldn't put larger profile tyres on there as it'll affect the gearing and make the handling even wobblier.
Offline Khare
  • The bear that khares
« Reply #17 on: 28 April 2011, 18:48 »
+1
Offline Ninj
« Reply #18 on: 28 April 2011, 19:04 »
You couldn't fit a larger profile tyre without throwing the speedo out.  For instance your speedo would read 1.6% slow with a 55 and with a 60 = almost 5% - doesn't sound much but enough to get you points  :cry:
Also, by fitting larger profile tyres you are increasing the flex in the sidewall which may affect handling (impossible to quantify but it's the reason performance cars don't use them).
By going to a 195/50 vs a 205/50 your speedo will very slightly over read - Id prefer that and the cash in my pocket every day.
As a rough ballpark, (only compared one brand) price wise the cheapest (so you could therefore assume most popular sizes) are the 195/50/15
http://www.miata.net/garage/tirecalc.html (cos it didnt work on my first link)
Offline vr6lew
205 vs 195
« Reply #19 on: 28 April 2011, 19:57 »
I always find 205's better suited to the wheel size
