Author Topic: MK3 Golf Anniversary (Operation OEM+) - Vandalism - Thanks Yeovil  (Read 337252 times)
Offline Shady Pioneer
  • graphic designer.
Wont make any difference to your tracking........ :huh:
Might give it a go then.  :grin: Tell you what's annoying, putting on a 3mm spacer with a wheel in front of it.  :grin:
Offline lewis1641
  • stuck in the 90's
have the wheels been split recently? could vw the rim bolts are loose? a mate had that kn his rs4
As posted switch front to back and see if any better
Offline Bellend
Could be tyres if the wheels have balanced up fine. Even new tyres.
Where all my moneys went.
  • graphic designer.
Changed the aerial to a Polo 6R aerial yesterday, many thanks to Woosh for supplying and GTI novice for confirming they fit MK3s. Just need to blacken that trim now!
From this:
To this:
Offline dom
  • Back in a Mk4
Your running 3mm spacers? If so then that's the most likely cause of your wobble, I ran 5mm halfords ones for a couple of days before ditching them due to the wobble they caused :angry:
Offline DanChave
Looking sweet Shady! Personally I am a fan of the black roof though :)
Offline brett
not a problem mate happy to help someone for a change lol,just gone to change my username so dont get called gti novice as no longer a novice as such and cant grrrr lol
  • graphic designer.
 :grin: Cheers bud. If you want your name changed PM jv and he will be able to dirt you out :)
  • graphic designer.
Got a new backbox to put on which should tidy up the rear a bit. Here's hoping any way. Gave it a good clean and will be getting the garage to put it on this week hopefully.
