Author Topic: MK3 Golf Anniversary (Operation OEM+) - Vandalism - Thanks Yeovil  (Read 337473 times)
Offline Shady Pioneer
  • graphic designer.
Re: Flash Red MK3 Golf 20th Anniversary - Wheel bearing issue
« Reply #260 on: 02 June 2011, 20:07 »
Feeling sorry for herself as she hasn't got shiny shoes, or new shoes.
Offline trog_nfs
« Reply #261 on: 02 June 2011, 20:41 »
Have you completely broken fixed your water leak?  :tongue:
  • graphic designer.
« Reply #262 on: 02 June 2011, 21:12 »
Getting sorted on Saturday fella. Won't know for sure if it's the fix though until a week or two later (see if coolant is dropping).
Offline Guy
« Reply #263 on: 02 June 2011, 21:15 »
thoroughly clean the area surrounding the bits you are replacing... then look for water deposits on the area after a drive... should be easy to spot
Offline trog_nfs
« Reply #264 on: 02 June 2011, 21:18 »
Advantage of G12+ is you get lovely pink deposits around any leaks. Thats how I found my radiator was seeping.
Offline JC
  • Back in the North.
« Reply #265 on: 02 June 2011, 21:19 »
breakdown at VF iti is then  :grin:
Offline Guy
« Reply #266 on: 02 June 2011, 21:19 »
thats the one... except its G12++ now
  • graphic designer.
« Reply #267 on: 02 June 2011, 21:20 »
I had one bad experience chuff.  :grin:
Will do Guy, was going to clean it up. Trog, I use Halfords pink crap, it had deposited nicel around the leak though so should be an easy spot if it still leaks.
Offline Guy
« Reply #268 on: 02 June 2011, 21:25 »
so you can spot it straight away instead of waiting two weeks?!
Offline dom
  • Back in a Mk4
« Reply #269 on: 02 June 2011, 21:56 »
 :grin: :grin:
