Author Topic: NOS  (Read 6108 times)
Offline Sam
  • Sam I am
Re: NOS
« Reply #30 on: 26 April 2011, 17:08 »
I have got the software somewhere, its on a floppy disk and runs in DOS!!!!!!
I am in North Wales so its a long way to Stealth.
I have a really old laptop that I used to use in the car when I was playing with the setup, probably will dig it out and see if it still works, you also need a serial cable and it has to be wired a certain way.... (One of my engineers made me up the cable, could probably find the wiring diagram if required, or just use a multi-meter and work out the pin connections from my lead)
If all of the above could be done you would help no end! Im sure one of the lads at my uni could look at the coding and make her run on xp too. Is there any way I can get hold of a copy of the disk and wiring diagram for the cable?
Offline tomp
Re: NOS
« Reply #31 on: 26 April 2011, 21:11 »
PM me your email address and I will email you what you need, you may have to bear with me as I am gonna have to find the disk and a floppy disk drive to read it!!!
Have a look here for wiring diagrams:
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=77094
Pretty sure that's what you need although I could check my lead as it lives in the glovebox (Which is somewhere in my garage) to confirm.....
Offline bodga
  • F reg GTI 16v
Re: NOS
« Reply #32 on: 26 April 2011, 23:02 »
tomp, I work with a bloke that races his bike at santa pod with NOS, i asked him a while ago for another thread, i havent tried the links. He buys his NOS stuff from the states (cheaper i think)
http://www.golfgtiforum.co.uk/index.php?topic=160477.msg1479661#msg1479661
and this is his bike:
http://www.youtube.com/watch?v=M8fjKlLKoZo
http://www.youtube.com/user/penguinracing#p/a/u/2/CPX-dAhfu-U
Hope it helps
Offline tomp
Re: NOS
« Reply #33 on: 27 April 2011, 00:57 »
Cheers for that, links are good, followed one for a mk2 16v install.
That bike sounds mean!
