Author Topic: exhaust fitment  (Read 1860 times)
Offline stainesy
Re: exhaust fitment
« Reply #10 on: 21 April 2011, 22:05 »
My maxnex one measured 50mm outside diameter mate.
and that waas same size as standered one then i take?
so i will need 52mm flexi pipe then. nice1 cheers
Offline neil1780
Re: exhaust fitment
« Reply #11 on: 21 April 2011, 22:12 »
Yes mate mine is joined to a standard centre section.
V6 4MOTION
Offline LENNOX
Re: exhaust fitment
« Reply #12 on: 21 April 2011, 23:53 »
with regard to space, is it ok to remove the heat sheild from between the backbox and the spare wheel well and fuel tank to make fitting easier as this would mean i can add a hanger to make my ill fitting uni box a better fitting uni box, or is it likely to explode on long journeys? :P
Offline stainesy
Re: exhaust fitment
« Reply #13 on: 22 April 2011, 06:54 »
I personaly would not feel safe in a car with exhaust against fuel tank with no heat shield.
Offline dazzawest1987
Re: exhaust fitment
« Reply #14 on: 22 April 2011, 07:44 »
I left my heat shield on and the exhaust is right up against it, onlyproblem with that it rattles and knocks ocassionly. It's only against the spare wheel well no the fuel tank
Offline stainesy
Re: exhaust fitment
« Reply #15 on: 28 April 2011, 20:34 »
ok had a try fit with my exhaust today and its going to fit perfectly. pipe is 50mm same as golf aswell so just need a 51mm flexi pipe now to fit it.
realy want to fit it now and dont wan to wait till next weekend for a flexi pipe to turn up if i go ebay.
where would i be able to go buy a flexi pipe from?
