Author Topic: oil pressure problems still!!!!  (Read 4088 times)
Re: oil pressure problems still!!!!
« Reply #10 on: 19 April 2011, 21:00 »
right,I just fitted the vdo sender into the t-piece and refitted the standard blue sender into the side of the head.I have no flashing anymore not even at idle and the vdo is reading just under 1 bar at idle.When i give it some revs my gauge goes up to just under 3 bar.
Am i about right then now??
Yes sounds about right.
would an engine flush do any harm???.
Not keen on the stuff tbh.
« Reply #11 on: 20 April 2011, 09:43 »
i wouldnt bother with the flush as it seems the oil pressures are healthy, just keep up the oil changes. unless you know the engine is full o sludge you dont need to worry
