Author Topic: oil cooler?  (Read 1880 times)
Offline antogoof
  • bbm mk2 g60
oil cooler?
« on: 18 April 2011, 23:07 »
wanna put an oil cooler on the mk2 saw 104 on th` mfa the other day on the motorway, ok it was at 110 but still i wanna put one on, but dont know where to start. any ideas. :smiley:
mk2 bright blue met bits wanted in north west.
Re: oil cooler?
« Reply #1 on: 18 April 2011, 23:50 »
Look around for Mocal kits
Excellent choice :afro:
Offline Thom89
  • Looking for an "Icebreaker"
Re: oil cooler?
« Reply #2 on: 19 April 2011, 00:19 »
2nd that
Thom
Offline Diamond Hell
  • Opinions я Us
Re: oil cooler?
« Reply #3 on: 19 April 2011, 14:19 »
Mocal are ok, but retain the OEM cooler as it also warms up the oil faster, keeping your engine healthy for longer. When did you last change the oil? Sort the root issue before attacking the symptoms.
Offline Adam
Re: oil cooler?
« Reply #4 on: 19 April 2011, 14:23 »
I fitted a Mocal Oil cooler and it certainly did it's job. I was seeing 120* on a very hot day of driving it hard. They do also offer a sandwich plate with a thermostat to allow the oil to warm up quicker thats quite handy.
Down Hill From Here.
Offline antogoof
  • bbm mk2 g60
Re: oil cooler?
« Reply #5 on: 22 April 2011, 17:09 »
2k ago? i do it regular really its every 3k and i only drive it at weekends and i always check it.
Offline bodga
  • F reg GTI 16v
Re: oil cooler?
« Reply #6 on: 22 April 2011, 17:22 »
Is it a valver? Mine runs at them temperatures, fan cuts in and out no worries.
I'm not an expert on oils but they make a difference on running temperatures, also change your coolant if you haven't already done so :wink:. Flush the coolant system though with a hose before filling up again with g12/water
