Author Topic: bleeding brakes, soda stream brake fluid  (Read 28541 times)
Offline danny_p
Re: bleeding brakes, think I've done something daft
« Reply #10 on: 10 April 2011, 12:03 »
if the valve has air in it you have to clamp it open sometimes else it'll never bleed through properly.  if it's full of fluid and all your doing is pumping fluid through it there is no need.
all the VW's have gone bar 1.
Offline danny_p
« Reply #11 on: 10 April 2011, 12:05 »
just a thought when you were bleeding the barkes did you keep pushing the brake pedal right down into the carpet ?
Offline mk2bal
« Reply #12 on: 10 April 2011, 12:40 »
Was speaking to a mechanic mate of 15years about this the other day. He said only to adjust them when you lower the car, but never for bleeding.. He's never had problems on his mk2, and said he uses a home-made 1 man kit (non pressurised), on all cars at work, never touches the bias valve and never had a problem.. However I can imagine in some situations it may benefit from being clamped if your having a complete mare bleeding up the rears??
Offline clipperjay
« Reply #13 on: 10 April 2011, 14:06 »
Yes all it takes is a caliper to be 90% full when pumping fluid which is why I tend to turn them up side down when bleeding to make sure they are full of fluid and not air.
The simplest method is to get a pint glass top up resivoir then long plastic tube over nipple and pump the brakes four times until the resivor needs topping up.
Never bleed it bellow the line so no air gets in.
Its a longer method of bleeding, but two man jobbie can be just a pain in the arse, as he never pumps and lets go at the right times, hence a pint glass and longer tube so only fliud goes back up the nipple and no need to do up the valve nipple. :wink:
If you are really having problems I would raise the passenger wheel arch higher than the other four wheels then do the same thing bleed in order, but raise the back up first due to the gravity helping to get more forced fluid in the back!
I've never had to muk about with bias valves unless it was retro fitting different calipers on the back and needed adjusting.
Offline Neo Badness
  • Feet are for pedals
« Reply #14 on: 10 April 2011, 23:00 »
Thanks for all the replies.
Due to being pushed for time today, was putting in a bathroom floor, plus other odds and ends. I ended up biting the bullet and taking it to local garage and getting them to pressure bleed the system(£35.00 :shocked:). The guy ended up doing it twice as couldn't get a decent pedal. It's still not fabulous but an awful lot better than it was. Made me feel a bit better that the guy struggled too, as daft as that sounds. Not just me then.
I was using a bleed tube/ resevoir and pumping it until no bubbles came out with the all 4 wheels off and on axles stands so it was same level as it would be if the wheels were on.
In for retest tomorrow so if it still fails on spongy pedal I'll take it straight back to the garage for a refund...
Then set fire to the car... :evil:
Offline SoundillusioN
« Reply #15 on: 10 April 2011, 23:14 »
Sorry dude, been too busy on my own car to go through the forum and only just seen your thread.. next time, invest in one of these.
It uses pressure from a spare wheel and worked wonders on my brakes!  :cool:
« Last Edit: 11 April 2011, 17:20 by SoundillusioN »
Offline Neo Badness
« Reply #16 on: 11 April 2011, 00:00 »
Sorry dude, been too busy on my own car to go through the forum and only just seen your thread.. next time, invest on one of these.
Cheer bud, I might do if I ever go near the brakes again... Was looking at making my own pressure bleeder but didn't have time. Hope you got the belt sorted and the tappets etc :smiley:
Offline Mr Blue
« Reply #17 on: 11 April 2011, 00:41 »
eezi bleed kit  :cool:
Offline emery1990
« Reply #18 on: 11 April 2011, 09:09 »
I've got one, they are very good, only cost £15 on ebay.
Offline moutains
« Reply #19 on: 11 April 2011, 09:13 »
the only difference between dot.4 & dot.5 is dot 5 has a higher boiling point
