Author Topic: Mot fail and Cat decision  (Read 2417 times)
Offline kingbling83
« on: 05 April 2011, 18:25 »
Hello boys and girls, today i had the Mot and it failed on the de cat with emitions and a slack hand brake cable.
Will i notice a massive difference with power if i put the cat back on and get rid of the de cat.
My car is running a ko3s ecu custom remap fmic and loads of other tings
1.8t AGU KO3S turbo custom remap Total tuning, Allard FMIC, samco Turbo inlet pipe, Forge 007p DV, Blue flame exhaust DE Cat, 3" downpipe, ATP oil catch tank, Kinetic manifold, forge boost hose kit, Drilled/Grooved discs, EBC green stuff pads, VF engineering mounts, 4 motion front valance, forge boost gage.
Offline cullygti
Re: Mot fail and Cat decision
« Reply #1 on: 05 April 2011, 18:35 »
just put the cat back on to pass the mot and then take it back off once its got an mot kinda of obvious this is what you got to do really mate  :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 05 April 2011, 18:43 »
you will notice a difference if you put a standard cat back on, the difference in bore size of the pipes is massive.
If you can find a friendly MOT station or just do as cully says :smiley:
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« Reply #3 on: 05 April 2011, 18:44 »
+1 loads of ppl do this,im pally with my mot tester so no probs :wink:
« Last Edit: 05 April 2011, 18:46 by symsymma »
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline kingbling83
« Reply #4 on: 05 April 2011, 18:57 »
Cheers, i aint very good with this sort of thing as brought golf with mods, ill defiantly try and find a decent mot station next time.
Offline richw911
« Reply #5 on: 05 April 2011, 19:02 »
You someone was going to post it.
http://www.dft.gov.uk/vosa/repository/Roadside%20Emissions%20Check%20Leaflet%20.pdf
And that it would be me  :laugh: :grin:  :kiss:
Offline symsymma
« Reply #6 on: 05 April 2011, 19:04 »
ask ppl u know etc if they know anyone im sure ull find somewhere that wil do it?u just put the decat on after the mot if u catch my drift :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 05 April 2011, 19:08 »
get back in your box Rich  :grin:
Offline richw911
« Reply #8 on: 05 April 2011, 19:18 »
 :kiss: :kiss: :kiss: :kiss:
« Reply #9 on: 05 April 2011, 21:46 »
Not worth the hassle really, better to run the cat as they are clamping down on decats.
