Author Topic: using loads of water! - help!  (Read 3422 times)
Offline richandhazel
Re: using loads of water! - help!
« Reply #10 on: 31 March 2005, 11:46 »
When you take the camshaft pulley off, you will see the seal that 'rubjonny' is on about. Its a round 'U' section seal that goes around the end of the shaft, it is clamped by that first bearing cap. I agree, you should definately replace it.
Offline acko
« Reply #11 on: 02 April 2005, 18:39 »
Cheers for the help guys,
I replaced the oil seal today, got everything bolted back together, Those C-shaped clips that hold the downpipe to the manifold are an absolute arse! Why couldn't there just be a flange with some bolts!!!!!! took me  ages with the little tool, and the clips and the inaccesability and wiggling and the wahoyhoy.  :laugh:
Anyway, being a novice really with cars this is by far the most major thing i've ever done, i've only really dabled with changing exhausts and little bits which are a doddle. I was really pleased with myself, got it all done and then filled it up with oil, no leaks! filled it up with water, pissing everywhere! one of the hoses which bolts to the head had not been tightened properly coz the bolt rounded like every other rusty nut on my car!  :angry:
Gona have to wait a few days now coz I need to give it some hasstle to get it out and put some new uns in. Theres always sumet int there, just when you think your on to a winner...
