Author Topic: what can i get a 02a gearbox off?  (Read 4507 times)
Offline matping
  • MK1 20vT MK5 GTI T
Re: what can i get a 02a gearbox off?
« Reply #10 on: 30 March 2011, 22:33 »
i guess if the box is allready hydraulic ill only have to change the pedal to hydraulic  ??? rally pedal box with slave cylinder for easy option ??
Offline LazyLunatic
  • MK3 20VT Project
« Reply #11 on: 31 March 2011, 13:43 »
02A boxes are all hydro clutch. You can convert the box to cable clutch or convert the car to hydro clutch.
Offline matping
« Reply #12 on: 31 March 2011, 20:53 »
i had a look at the box thats on the car at the minuet the 02j and im sure its hydraulic  i cant see no cables on the box except the gear selector ones   any ideas??? theres a hydraulic pipe aswell on the top of the box
Offline lord14
« Reply #13 on: 31 March 2011, 23:08 »
yeh all the mk4 golf gearbox's are hydraulic, i jsut converted the my mk1 pedal to hydraulic by cutting a hole int he bulkhead bolting the mastercylinder in and then making brakes and so on for it to work correctly and then used the mk4 slave cylinder and clutch line
Offline matping
« Reply #14 on: 01 April 2011, 07:47 »
ahh sweet  that should be ok then ill keep you posted what i achieve !  :rolleyes:
« Reply #15 on: 04 April 2011, 11:39 »
VR6 box no good as its different bell housing, same goes for V5, R32/36 etc. basically, you need a 4 pot one
Offline matping
« Reply #16 on: 04 April 2011, 20:57 »
whats the best box to go for ? gotta have the 100mm flanges for the conversion drive shafts
« Reply #17 on: 07 April 2011, 10:31 »
its your call, depends what kind of ratios tyou want. the boost boys favour diesel boxes though for the long ratios
Offline matping
« Reply #18 on: 07 April 2011, 12:08 »
thanks for the reply   right erm im  putting a ko3s and TIP  on her shes allready remapped so boost wise im all good  i could do with torque !! you got any suggestions ?
ive been offerd a box from  vw 02a abf gearbox mk3 16v ??
or if i should go diesel box am i looking for something like off a mk4 tdi ? would that be 02a with the 100mm flanges
« Last Edit: 07 April 2011, 12:20 by matping »
