Author Topic: Top shock mount  (Read 3491 times)
Re: Top shock mount
« Reply #10 on: 17 March 2005, 09:12 »
You can buy it from VW and GSF, and apparently Halfords sell it but were unable to get me one when I went in to ask!
You could also make one by grinding an old socket to the right shape :)
You live anywhere near Bracknell, I have one you could borrow for a bit.
Offline Horney
Re: Top shock mount
« Reply #11 on: 17 March 2005, 10:06 »
Cheers mate that's a really kind offer. I'm in Henley so not too far from Bracknell. I'm currently ringing round a few of the local garages and seeing if anyone will lend me one. If that fails then I'll try GSF and if they have one shoot down there at lunch. If that fails then I may have to take you up on the offer.
Nick
Offline Horney
Re: Top shock mount
« Reply #12 on: 17 March 2005, 14:05 »
Right no joy on getting a special tool anywhere so in true bodge-it style I'm making my own.
Take 1 deep socket and attack with angle grinder until it fits.
Wish me luck folks!
Offline CARPY25
  • Corrado 16v
Re: Top shock mount
« Reply #13 on: 17 March 2005, 14:32 »
Don't forget to mark the position of the hub carrier into to bottom of the strut before you remove the two bolts ,don't mix the bolts
up one could have a thinner shaft to allow for the right adjustment
if you don't your camber will be out and you will eat front tires   :cry:
did mine last week "h" plater 14 years old  and the slotted nut came off with pointy nose pliers, if you have an air gun it's a 20 minute job
good luck
             Rob
Offline Horney
Re: Top shock mount
« Reply #14 on: 17 March 2005, 14:40 »
I dream of owning an air gun!
Offline CARPY25
  • Corrado 16v
Re: Top shock mount
« Reply #15 on: 17 March 2005, 14:48 »
without an air gun you may need a special socket just to get the top nut  off
if its tight you need to hold the shock rod with an allen key and then turn the nut
if i were you i would try to lossen that before i jacked it up to take the wheel off
could save your self wasting time and doing the work under the arch just to hit a stop
on the top nut
Offline Horney
Re: Top shock mount
« Reply #16 on: 17 March 2005, 15:18 »
Cheers for the tips CARPY25,
I'll be following the haynes manual and swearing where approriate. Hopefully no dramas. I need it done tonight or no romantic weekend with the missus :-(
Nick
Offline Horney
Re: Top shock mount
« Reply #17 on: 17 March 2005, 19:06 »
Damn!
I can't even get the first nut off! Given up and hit the beer. Looks like I'm a two car owner who's going to be hiring a car for the weekend!
Offline CARPY25
  • Corrado 16v
Re: Top shock mount
« Reply #18 on: 17 March 2005, 21:03 »
gutting hope you tried the top nut first and didn't lose to much drinking time  :wink:
tool you need always on ebay about a fiver or pop down your your local tire bay spin them off with a gun then
use a mole grips on a socket and a 7mm allen key down the middle to retighten to drive it to where your going to do the job
nice and slow do the job  top nuts only 44 newton mts if i remember rigthly so tighten back up should be ok with the mole grips
bet would let you do the job in their car park for a couple of pounds cheaper than a hire car
Rob
Offline Horney
Re: Top shock mount
« Reply #19 on: 17 March 2005, 21:46 »
I needed the car for tomorrow lunchtime so a hire car was the only option as the mini has a siezed clutch which I'm fixing next weekend.
I couldn't get the first nut off the shaft just spun. Put an allen key in to stop it spinning and it just would not undo no matter how much we grunted and swore. :-(
THink I'm just gonne chuck it in the local VeeDub garage and hang the expense
