Author Topic: Loose engine mount...?  (Read 6559 times)
Offline delirical
  • Like a g60
Re: Loose engine mount...?
« Reply #20 on: 04 April 2011, 09:38 »
Yup but its sorted now.
Friday eve i got home from work, jacked her up and got a torch to see what the hell was going on.
Basically there were NO bolts in the bottom of the subframe  :lipsrsealed: i couldnt believe it!
Tom came round with a bag of bolts and the first two we tried happened to the correct ones, so umm job done! Thanks peeps! I feel like a right idiot that i didnt even check underneath before posting  :embarassed:
Offline mk2bal
« Reply #21 on: 04 April 2011, 18:31 »
If you mean subframe to shell you mustve had some in.. I had one come loose months after eng conv, and the car felt quite dodgey, as if it was going to crash and fall apart on corners! Wasn't until I saw about 8 whole turns of thread showing on 1 bolt that I realised. That was days later, after wondering what it was, and still thrashing it a bit. Moral of the story is if it feels dodgey-it probably is dodgey..get straight under for an inspection!!
Offline Dolly
« Reply #22 on: 04 April 2011, 18:44 »
it might worth lock tighting the bolts, ive heard the extra vibrations from the solid front engine mount can vibrate bolts loose, there definatly was bolts fitted before by the way  :shocked:
Offline delirical
  • Like a g60
« Reply #23 on: 05 April 2011, 08:56 »
Haha!! yea no worries mate i know there were bolts fitted.
You are right about them vibrating loose though as it happened to the top bolt in the front engine mount a couple of months ago, that was tightened back up with locktight.
Ive fitted new bottom bolts with gripping washers so that should do the trick. :smiley:
