Author Topic: Tyre Problems -  (Read 4668 times)
Offline ajmoir36
Re: Tyre Problems -
« Reply #10 on: 22 March 2011, 21:20 »
Hi Guys
I know that tyres have seen some enthusiastic debate on the forum and I thought I'd post this here in case it's of any use to anyone.
I had the misfortune of losing my back passenger wheel twice to debris in the road (a screw and then a sheared nail). The first time, the screw ran into the very edge of the tyre, almost into the wall and it was deemed unsafe to repair. The second time, the nail went into the centre of the tyre but on looking to remedy the problem, the internals of the tyre had literally unravelled and the rubber fragmented. I must have driven 200-400 yards before I could pull in but the tyre was not recoverable. Considering I won't even drive over a plastic bag in the road, it was just damn bad luck that cost me several hundred in repairs.
So, I wrote to Michelin and this is the response I got:
"The repairabilty of any tyre depends upon various factors such as the diameter of the hole, the angle of penetration and possible run flat damage.
A tyre that has been run underinflated or flat may have suffered irreparable damage to the internal structure.
Also, in many instances, a penetration could have happened some considerable time earlier without the driver being aware resulting in a gradual loss of pressure. If the tyre sidewall is damaged, then unfortunately the tyre is irrepairable.
Should you wish, you can send the tyre back to us for a second opinion on its repairablity by following our complaints procedure detailed below:
The BTMA (British Tyre Manufacturers Association) have put in place within the UK, a system to allow products to be returned free of charge to the manufacturer. The aim of this system is to ensure that problems are addressed & customers compensated, where applicable.
Your tyre needs to be returned, under complaint, to a tyre distributor of your choice. Returning the tyre via the distributor/garage that originally supplied or replaced them may prove to be the most effective.
Your details should be noted, i.e. Name/address, along with a description of the perceived fault/problem. The tyre, along with the noted details, will be sent to the tyre manufacturer where the tyre will be examined and a report on each tyre involved will be produced. You will receive a copy of each report along with compensation, where applicable. Comment can only be made on the actual tyre received for examination.
The process is listed as taking 28 days, but usually takes 2 weeks. It is advisable to obtain a receipt for the tyre left with the distributor, as proof of responsibility should your property be mislaid.
May I suggest, that if you have not received a written response from Michelin within 28 days from the date of leaving the tyre with a tyre distributor, that you contact us directly on 0845 3661590.
Should you require any further assistance please contact us on 0845 366 1590 (UK & NI) or 0044 (0) 1782 401590 (ROI), quoting the reference number above.
So, if anyone has a problem with a tyre, take note of the above as I wasn't aware of the procedures nor was the garage so missed my opportunity to have the manufacturer assess whether there was an issue with the quality of the tyre. With only pictures as evidence, it makes it much harder to achieve any sort of satisfactory resolution.
Hope this helps.
Thanks
Alex
I have to admit everyone hates Bridgestones RE050A but I drove a front tyre with less than 10psi (didnt notice some scrote had let the air out, finger marks next to the  valve on the dirty wheel gave it away) on my mk5 with 17"s.  Anyway I did 120miles with speeds up to 70mph and 5 people in the car and didn't notice until I got home.  There was no difference in handling that I could tell, apart from I kept wondering why my mpg was not very good.  Anyway to cut a long story short I blew it up and had it replaced and I had a look at the tyre after they removed it.  It had over a cups worth of rubber running around in the inside made up of small beads and you could see the two lines where the alloy had run around on the inside of the tyre and the sidewalls were knackered but the tyre held to gether all that time.  Which impressed me alot.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline am1w
Re: Tyre Problems -
« Reply #11 on: 24 March 2011, 00:13 »
ajmoir36:
Most of the Premium Tyre brands and others not rated as such, are pretty tough and would have 'held up' just as well.
However, the Bridgestone Potenza 050A is an old tyre design and not worth its premium cost or rating in comparison to the newly released Goodyear Asymmetric 2, Contnental 3 and 5P, Michelin PS3 and Pirelli P Zero competitors. Bridgestone should drop its price by 30% for it to remain even mildly competitive.
Sad but true.
