Author Topic: Cruise control retrofit  (Read 9395 times)
Offline quinnii
Re: Cruise control retrofit
« Reply #10 on: 15 March 2011, 19:07 »
Excellent, thanks Doc!  :wink:
You have a donation in mind?
Im paying my one for the RR tonight so i might aswell do them both at the same time  :rolleyes:
2009/59 Candy White Golf GTI DSG
Winter Pack
RNS510 Ver C
9WZ VW Premium Bluetooth
OSIR O-Shift GT Paddles
Offline stokeballoon
« Reply #11 on: 15 March 2011, 19:24 »
I have not looked at the link yet as i don't want to screw my cookies up but
Anyone know the part number for the stalk etc for a 2010 mk6 GTI?
Snoopy, I used the below on my MY10 Roc R.
Slip ring controller 5K0 953 569H
Stalk 5K0 953 502 B 9B9
The set up on a MY10> Roc was different to a 59 plate.  The two stalks come as one piece, and the SW cont is part of the slipring.  It is all fairly easy to do, SW off, 3 screws and a few plugs and the Slipring and SW cont comes off, 3 spring clips and the Stalks pull off, then the reverse and code.
Offline Keithuk
« Reply #12 on: 15 March 2011, 19:43 »
There appears to be a few part numbers 1K0 953 513 G 9B9, 1K0 054 690 B, 1K0 054 690 A I know it says Jetta but they are common on alot of models. Just Google the part numbers.
I've been thinking about getting a cruise control switch. If you Google it there are loads fitting tips and kit needed on different models.
The thing is VW don't do things simply you can't screw the switch on from the side you have to remove the wheel. Anyone got any tips about removing the wheel and airbag that we should watch out for?  :wink:
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline quinnii
« Reply #13 on: 15 March 2011, 19:51 »
1K0 953 513 G 9B9 Is the model number of the stalk which i got, its suitable for the 2006-10 Jetta as far as i know.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=380307321626&ssPageName=STRK:MEWAX:IT#ht_1606wt_907
Got mine cheaper than this though  :wink:
Winter Pack
RNS510 Ver C
« Reply #14 on: 15 March 2011, 20:23 »
I believe there was a design change.  On my Roc MY10 (delivered March 10) both stalks were one complete piece.  The earlier variant has single stalks.  Not sure if the same on the Golf...........
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #15 on: 16 March 2011, 12:57 »
£10 sounds fair, don't pay for the cruise until it's working please  :wink:
Offline quinnii
« Reply #16 on: 16 March 2011, 19:27 »
No problem, Thanks Doc  :grin:
Winter Pack
RNS510 Ver C
Offline Keithuk
« Reply #17 on: 16 March 2011, 19:50 »
stokeballoon are you from Soke or is that just your chosen username?
Offline The Doc
« Reply #18 on: 17 March 2011, 04:56 »
I'll do a how to but in the mean time there is this: http://www.golfgtiforum.co.uk/index.php?topic=178713.0
Offline Keithuk
« Reply #19 on: 17 March 2011, 17:37 »
Cheers Doc.
