Author Topic: Idling issue 1.8t  (Read 3035 times)
Offline Jayz
Re: Idling issue 1.8t
« Reply #20 on: 15 March 2011, 23:26 »
Check your breather hoses that they haven't split. On my agu the culprit was the s shape pipe which is located behind the dipstick going into the bottom of the intake manifold.
Offline thatwillis
« Reply #21 on: 20 March 2011, 17:31 »
So i replaced the thermostat today argh that bottom bolt is a bugger to get to without a good socket set. (which i left at work)
Gonna take her for a spin and see if she gets to temperature.
« Last Edit: 20 March 2011, 17:47 by thatwillis »
Offline thatwillis
« Reply #22 on: 20 March 2011, 19:11 »
ahhhh swap one problem for another!
Electrics all went a bit haywire, Battery now isn't charging! and i can't work out why! All i did was unplug 2 plugs and replace them  :sad:
Any ideas? Battery light is up on dash.
Offline richw911
« Reply #23 on: 20 March 2011, 19:12 »
Check alternator plug is fully home  :wink:
Offline thatwillis
« Reply #24 on: 20 March 2011, 19:33 »
yeah i tried that  :cry: all properly in place all clean connections. The small nut that holds the thick earth cable onto the alternator is just holding the wire isnt it? (Not the main nut that hold the earth on.)
