Author Topic: Dan's N5T LO daily - VR6 Turbo build starting #95  (Read 342560 times)
Offline lemski
  • 16v
Re: Dan's new daily - Broken suspension (not DH approved)
« Reply #450 on: 21 June 2011, 08:08 »
I see av been away for the weekend, come back and your car is again broke. Like souind of the engine though.
Offline Dmonday
« Reply #451 on: 30 June 2011, 19:45 »
Fixed wheel bearing & hub lastweek, now running on all 4 cylinders.. just need a new TB and need to invest in a welder to do my exhaust.
Not low, not clean.. but it's kinda working..
One arch semi-bodged until we chop them out;
dirty ibiza by d.monday, on Flickr
Nice coilover :rolleyes: stripped out.
stripped out by d.monday, on Flickr
p.s - My camera's f**ked.
My friends respraying the car for me soon :) not sure weather to keep it the same colour or change it up a little, go for something a different? Engine build also coming soon..
Edit: Also got new headlights from where i bumped it, now sitting flush!
Offline Jack3559
« Reply #452 on: 30 June 2011, 19:50 »
What are you on about not low!?
Looks awesome.
What's going on with that coil over though?
Offline Dmonday
« Reply #453 on: 30 June 2011, 19:59 »
Looks awesome.
Will be lower once i whip the engine out and sort the rear arches :) Coil overs just popped through, can weld a plate on the inside but strong washer is a temp fix :D
Offline Bellend
« Reply #454 on: 30 June 2011, 23:06 »
Is it the circlip popped off mate on the coilover?  :smiley:
Where all my moneys went.
Offline Dmonday
« Reply #455 on: 30 June 2011, 23:07 »
Yeah dude :) well it hasn't popped off, its just managed to pop through, put washers on it and now they've popped through too, will have a play at weekend see what's what!
Offline Bellend
« Reply #456 on: 30 June 2011, 23:09 »
I don't think there's any point in using logic to try and work out why that happened.  :grin:
Offline Dmonday
« Reply #457 on: 30 June 2011, 23:09 »
:D :lipsrsealed:
Offline Dmonday
« Reply #458 on: 01 July 2011, 19:35 »
Hard to get a shot, but got longer high tensile bolts and doubled up on the rear camber..
Rear camber - Doubled up by d.monday, on Flickr
Offline cняis
« Reply #459 on: 01 July 2011, 22:50 »
This is just personal preference but (now I'm gunna sound ike an OAP) it looks like you've hit a pothole and bent the rear axle - the car looks broken with that much camber  :laugh:
On the plus side I love the banded steels  :tongue:
