Author Topic: What's your next buy?  (Read 13939 times)
Offline Diamond Hell
  • Opinions я Us
Re: What's your next buy?
« Reply #30 on: 04 May 2011, 16:51 »
Call you spell
Errrrr...
If you mean a track system to wind the camera along like this, yes maybe later.
This is the timer thingamy - bought cos it was cheap.  Someone tell it it won't do what I'm thinking of now.  :grin:
This is what piqued my interest in doing this: http://www.vimeo.com/22439234?ab
Obviously I'm not expecting anything like that, but it's something new to try and you've got to love that sort of thing.  Already got a number of projects to try out with it.
Offline shepgti
« Reply #31 on: 04 May 2011, 17:25 »
the one thing i will suggest dh is finding a decent bit of software to put it together as in my experience taking the shots was the easy bit.
  • Opinions я Us
« Reply #32 on: 04 May 2011, 17:37 »
Well I'll be starting with Premier Pro and if that fails I'll be upgrading my Quicktime to Pro - apparently it'll nail the shots all together from sequentially numbered images.
If I'm still failing, I have a mate who's done several, so I'll tap him up  :wink:
Offline shepgti
« Reply #33 on: 04 May 2011, 17:39 »
ive heard good things about quicktime pro
Offline Ridg
  • TDI - Soot Happens!
« Reply #34 on: 04 May 2011, 18:50 »
Call you spell
Errrrr...
yeah any sort of rail system / rig to move the camera between shots, the most interesting time lapse videos I've seen are shot from moving rigs, and you can knock one up on the cheap.
Premier Pro or after effects :afro:
Offline the_stink
  • A3 140 TDI
« Reply #35 on: 05 May 2011, 17:40 »
my next buy will be a new tripod! The only one is pretty 'over used' well its served me well for 2 years but the latch has had it
Offline Ridg
« Reply #36 on: 05 May 2011, 19:49 »
manfrotto :wink:
Offline the_stink
  • A3 140 TDI
« Reply #37 on: 06 May 2011, 08:01 »
manfrotto :wink:
yeah was looking at those, think there is a thread i started about 'what tirpod' and one kept coming up
Offline Gavo1989
« Reply #38 on: 10 May 2011, 16:00 »
The tamron 70-300mm Lens aint bad really for the money. I use it and its lasted a while
Took this down my local doc's. Got put in the local paper in a christmas comp lol
As for software goes cant beat photoshop cs5 if you can use it  :rolleyes:
What uses would you suggest for a sigma 10-20mm other than landscapes. Do you think it would be anygood for cars?
Offline Ridg
« Reply #39 on: 10 May 2011, 16:16 »
landscapes, interior shots with a small working distance, wide angle lenses usually have a close working distance so can be good for close up work (esp when combined with the wide angle of view).  Could be good for car work as you won't need to be too far back, but be-aware that anything that wide will have noticeable barrel distortion (normally correctable) although sometimes distortion can add to the image.
