Author Topic: if any one can help would be good  (Read 1640 times)
Offline g271uke
« on: 12 March 2005, 22:40 »
ihave a golf 1.8t and was gonna put a dump vavle on it but told not to now i have been told if you have the agu engin you are able 2 have 1 on there  and it wont cause any problems has any 1 had any problems wen have 1 on there car
Offline topher
  • Administrator
  • fully functioning
Re: if any one can help would be good
« Reply #1 on: 12 March 2005, 22:52 »
Assuming you want to replace your standard diverter valve for an atmospheric dumping one (that goes pssshhht !) and not just an uprated diverter (forge 007 etc.) then it's a case of "suck it and see"
Since the AGU relies purely on MAF readings where as later engines use both MAF and manifold MAP readings you won't get conflicting requested/actual boost. That's what seems to cause the problems. BUT! some people have reported poor running on their AGU's with atmos. dump valves.. others work fine. If you really want one then go ahead and try, if it makes the car run crap you can always send it back.
Offline g271uke
« Reply #2 on: 12 March 2005, 22:59 »
so if i buy 1 what 1 do i buy??
can it do any damage 2 my car though?
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 12 March 2005, 23:46 »
i think bailey make the kind of DV you're after. it wont damage your car, but like i said if it makes the car run badly then take it off.. there's no point sacrificing performance for the sake of a "whooosh" when you change gear :laugh:
Offline g271uke
« Reply #4 on: 13 March 2005, 10:38 »
oh yeah of course but what sort of thing should i look out for when it goes on or should i just be able to tell it playin up
